Notification Sound Problem(s)
Dec 22, 2010
13
OK, I am stumped.
I have notification set under settings-->Sound--> etc., etc.
I have 3 e-mail accounts set up in the phone. Each account has been verified to have notification sounds enabled via inbox-->settings-->notification, or whatever.
Seems like the e-mail notification sound is hit and miss, mostly miss.
Anything I'm missing? Or is this a bug. Have seen a few complaints from folks having issues with notification tones.
Not a how stopper, but, just wondering what gives......???
If all notifications is turn on in sounds - and you're still having issues, then turn off the phone and remove/reinsert the battery. That might fix the problem.
Good luck -
A battery pull will not fix the problem. If a restart doesn't fix it (which it probably won't) then a battery pull definitely won't.
Please don't start suggesting a battery pull for random problems that you're not sure how to fix.
OP - Please make sure that when you're missing the sound that you don't have the phone set to silent or vibrate. I've done that a few times myself. Also I've noticed, too, that sometimes I get a sound for things and sometimes I don't. I've verified that my settings are correct and all that good stuff, but still no sound 100% of the time. The one thing that has never failed me is that even though I don't get the sound I still get the actual notification. Personally that is enough for me to deal with Android having notification issues.
If anybody else has any USEFUL information or tips please post them here. Thanks.
OK, moved to K9 EMail client, all is working great. Have different e-mail notification sounds for each account. Seems like the issue was related to the stock client somehow.
BTW: I recommend K-9 email client. Works great for me.
cambium
