Notifications not working when Screen is sleeping ?
Same here, when app is left in foreground and screen off. The push arrives but no sound, no nothing...
I had this issue, where whatsapp stopped receiving messages and whatsapp web couldn't communicate when the phone had slept for a certain number of minutes, and the only way to get it working again was to wake up the phone (and/or open whatsapp).
The solution I found was to go into Settings -> Battery -> Power Saving / Ultra Power Saving. Either disable it completely, or disable it only for Whatsapp. After looking through the list of apps that were "being power-saved" I decided to disable the whole thing. I never currently reach a low battery status in my daily usage so I doubt it's an issue. If it's an issue for you, maybe you'll want to selectively disable it per app.
i just solved the problem. there is a setting under lock screen "automatically lock after sleep". set to "immediately". i had mine as 5 minutes so i wouldn't have to keep unlocking phone.. until the lock screen app takes focus, hangouts thinks it's still open, even though the screen is off. that's why there is no notification
Hi TIM,
I got the same problem... But your solution baffles me.. How can you get notifications that rely on an internet connection when your WIFI is turned off ??
Hi TIM,
I expect from the Internet connection that's provided in cell carrier data mode.
This solution worked, I noticed my yahoo mail app was optimized, so I disabled it, locked my phone, sent a mail from my laptop to myself and boom the phone came up with notification. So I think this should work for everyone, I use infinix note 4
This worked for me! Thank you. My situation was that I was using Android web chat (https://messages.android.com/) and unless my phone was awake I couldn't connect. Note: I also found this to be a problem with WhatsApp some of the time.
I turned off Wifi and suddenly it worked when my phone was asleep (with a little message saying I was using phone data). When I went in and turned off the power saving setting for both Messages and Whatsapp, I no longer have the issue. You're the BEST!!!
Same probem I had. In my case any of the solution listed didnt work. The pblm was, outlook app was not running in background when screen is off. I fixed it by, "Setting>Battery>under power consumption details>outlook> diable automatically disable when abnormall is detected option.
After months of having this issue I tried switching from the usual 5Ghz WiFi network to 2.4Ghz (my router broadcasts both as separate available networks) and ever since then notifications have been working properly even when phone is sleeping although I'm not sure why 5Ghz would have this problem.
How is it "widespread" when I only see a couple of people on this thread who have the problem? I don't have this problem.
Posted via Android Central App nexus 7
few reason:
1) this website is not as famous as Facebook, it's my first time seeing this site
2) this silly"bug" has been there since long time and not fix, ppl starts to accept this bug and gave up looking for solution as it is not really a very big issue, just need to use lesser WiFi or have to manually on screen to check for notifications. these are the by-pass solution that i and others are using while we put this issue aside.
3) other user had already addressed this issue, why do i or others who faced the same issue has to "re-post" and comment to this thread saying "hey i also have the issue"... we all are looking for fix and solution, no time to post a comment that doesn't help at all
Same problem here with S5 and WhatsApp Web. Testing "i just solved the problem. there is a setting under lock screen "automatically lock after sleep". set to "immediately". i had mine as 5 minutes so i wouldn't have to keep unlocking phone.. until the lock screen app takes focus, hangouts thinks it's still open, even though the screen is off. that's why there is no notification" now.
Pickle240
