Notifications, softkey home, lockscreen and factory reset issue. Help?
StrayElement
So, idk what happened, but quite a few functions have gone off now. I'm using the Moto x play on android marshmallow, and my main problem atm is the home button.
It's softkeys, so on-screen buttons, and the rest still work except for the home button. The only way it can function as a home button is if overview is opened and then home is pressed, otherwise it's completely useless.
As well as that, I can't get any notifications in the drawer or anything, and that includes permanent notifications like that of MacroDroid or even music apps, nothing shows up. Plus, I can't pull down the drawer further to get the glance settings or whatever they're called, as it just stops when I get to the (always empty) drawer.
My almost final problem is that the lock screen is completely bypassed when taking the phone out of standby, I have a pattern lock set but it just skips that and takes me straight into the phone.
Finally, I would have factory reset my phone by now but guess what?
That's broken too! I can't tap factory reset in the settings. That's also a big issue. And there are probably more problems that I haven't found yet :p
So, of anyone has any help that would be appreciated, as I haven't found any problem similar to this anywhere else.
Note that this is a moto x play, and so the battery can't be removed, and also I have tried rebooting it multiple times and gone into safe mode a couple of times too. Nothing has worked as of yet.
Re: Notifications, softkey home, lockscreen and factory reset issue
Issue with whatever ROM you have. If you haven't played around with root, it's not your fault. If you don't know what I mean, then you haven't done it. Steps to fix:
1. Boot into recovery. From there, factory reset the phone. I cannot tell you the exact process, so you must google it.
2. If that worked, you are done. If not, flash a custom ROM. Every phone is different, so I can't give much help.
3. If that worked, it's fixed, and you get a newer version of Android as a side effect. Awesome!
If not, it's a hardware issue. Sorry, you may need a new phone in this case.
KidColoringPage
