Nougat cat game
It won't work for me. :( I keep tapping the Nougat icon and nothing happens.
Once you see the cat icon under the N , follow this from the link:
Now, when you look through the "Edit" menu in Quick Settings, you'll see a cat icon—drag this one to the top. After that, it turns into a food dish, which you can tap to pick out a meal that's suitable for a feline. If you're lucky enough, your treat will catch a cat, and you'll get a notification with your new furry friend's picture, which you can then share with other people."
I don't know how you all are playing this, I tap and get the N
Then I tap and hold, a little cat face appears at the bottom and then it disappears again
There is nothing in my quick settings thingy either, no food, no cat
Feels like I'm missing a step here
Yeah, me too.
I finally got the food dish in my quick settings panel and tapped on it to select a treat. I picked chicken.
Now, what do I do to get a cat? Tap Nougat again, or will a cat randomly show up on its own?
Cat will randomly show up. A few posts back, someone posted a link to Reddit and someone did the calculations on which treat was best. Easiest is to just change them up.
Thanks. I figured it out a few days ago. I have about 19 cats now.
https://www.reddit.com/r/Android/comments/4tualq/what_i_know_about_cats_the_android_nougat_easter/
Ok, so a message popped up saying a cat has arrived, yay! I tapped on it to see it. Screenshot it with Bixby! Now how do I name it and where do I keep it?
If you long press the food dish you can see all your cats. Tap on one cat and change the name, long press and you can share or remove it.
Yay! I found a Pearl!
So I put bits in the dish, then got another message that a cat has shown up. Looks like it is still Pearl, though.
yes. the duplicates will drive you batty :P one cat again today with the rest dups. sigh so why am I still playing??? to get that cat of course. :D
up to 32 now, with two new ones out of the box this morning. no new colors. blue is the elusive color for me... and the green variants. I only have the (to me) very bright one.
I have 32 cats.
Here are the brown, which I have the most of.
Weiss-72
