Now Available from Verizon
Alright guys, I want the Z play instead of my current Z. Should I sell my z droid and buy a z play? I really value battery life and I really do not like the back of the moto z.
Aren't they the same backs? Are you within your return period or not? You could probably sell it on swappa.
If you value battery life, then the Z Play is your best bet. Take a look at some of the usage I'm getting. It's incredible! So pleasantly surprised.
Do you use your phone? I'm seeing 15 hours of battery use and only 10% of that is app use. Screen on time of 1 1/2 hours. You used the actual phone (call/talk) for 20 seconds.
I barely ever talk on the phone, but I use my phone a lot. Did you see the previous screenshot I posted where I had 8:20 SOT with 37% remaining?
As for the screenshot where I'd only used my phone for 1.5 hours in a 15 hour day - it's a weekend and I have a life. I was out and about.
You have only 10% app use. Do you disable a lot of apps from running in the background?
Not really. I only disable the Verizon bloat. I let everything else run. Most of my usage is Reddit, Android Central and other forums, Twitter, texting, web browsing, and a little bit of camera.
I keep brightness at 50 percent adaptive brightness.
I don't really do any gaming, so maybe that's part of it.
probang
