- Oct 1, 2010
- 4
- 0
- 0
I am doing ryan's fix on the captivate but am getting stuck after the reboot.. I scroll down in recovery mode and ther is no "appl sd card update to selcet..... any help ?
you should really check out the voodoo lag fix - it is better solution. It is the only one packaged with any of the custom Roms.
