Odin/Frija /Firmwares Place Them Here
Any word on when unlocked XAA VERSION S908U1UEU2CWAI which is the one ui 5.1 will be released for the s22 ultra? I need to flash immediately because I need to send it in to samsung as part of my trade in.
Thank you.
Thank you.
You can check manually under software update, if not one check Frija firmware tool but you can return this device without a update.
Sent from my SM-S918U1 using AC Forums mobile app
Thanks, I have unlocked which I put Tmobile firmware on, but now I want to switch back to XAA U1 before sending it in.
I'll check frija firmware tool, and just to make sure... I can send this back with Tmobile firmware on unlocked/unbranded phone?
Yeah they won't deny it , I've done it in the past
Thank you.
No, it doesn't HAVE to be on 5.1
You can send it back with ANY version installed
I have the s908u1, it's running android 15 with the binary 8. Can I use Odin to revert to the last android 14 firmware that also has the 8 binary? All of the android 14's before that were 7 binary. My bootloader is locked, but I was told as long as the binary matches it will work.
Welcome to AC!
Samsung usually prevents you from going to an Android version back but you can try with Odin the only thing is it will say failed in Odin and stop you from doing so.
Reactions: Laura Knotek
richardgroover
