[Official] CyanogenMod 7 discussion
Still using an unrooted Evo 4G, and am I right to assume that I can now root using CM7, despite having the Gingerbread update on my phone? Or do I still need to use Revolutionary? TIA
Yes you will have to root your phone using the Revolutionary method before you can flash CM,
Reactions: LAhanger
Anyone else having issues with the camera? My front camera displays upside down, and I can't enter video mode without the app crashing.
Trash the stock camera from the get go and use the MUIU Camera.
DumpedDuce Approves This Message
Thanks! I'll give that a try when I find the apk. In the meantime, I discovered that attempting to initiate a Skype video chat (which never does initiate) is what consequently causes the stock camera app to crash.
I did some quick searching and didn't see it, sorry if this is a duplicate post:
Does Cm7 support wifi downloading of mms? I know on sense-based roms this can happen but its been a while since I've been on cm7.
I finally flashed this after running Wam 2.2 for quite awhile. I'm running the latest stable release and have everything setup how I like it. I love the ROM, super fast and battery life is improved but there are two fatal flaws I can't resolve that I need to work as I use them daily. The first is the GPS, I know this was a problem in past iterations but I thought 7.1 had it totally fixed. It won't really find me at all, every once in awhile it'll lock in for a second but then it's gone again. The second problem is the wireless tether app. When I try to start it I get an error message that the tethering started with errors, in the log it failed at setting channel, setting essid, setting ad-hoc mode and activating wi-fi interface.
Are there permanent fixes for those two problems?
edit: found the answer to the wireless tether question
Do I download the miui camera first then trash the cm7 can and flash the miui? Do I just go into TB and uninstall the camera?
I've done a search and can't find the answer....grrrrrr.. Just went to cm7, and can't get a device to pair with my phone now. Tried my old headset, my car r dio which used to pair, re-scanned for devices, everything. No luck. Anyone got a suggestion? I am finally having decent luck with my applications.... but this won't seem to happen ....
Anyone have that GPS Fix link for CM7? The one where you run MSL## and flash back to sense? Can not find it for the life of me. Thanks
I just started using CM7 and I keep getting an error that says "process com.android.calendar " also get "process com.android gapps" FC, too...and my calendar won't load...any ideas. I wiped data, cache, and "dalchik", before flashing. I've rebooted and wiped cache/dalchik again w/o success...other things happening but these random FC's are bothersome. Also, no Swype and unable to open Amazon MP3 app. Thanks in advance, Mark Carter
:eek:
ALSO...my home key won't work.
No members online now.
monelmonel
