OFFICIAL: US Note 4 Avaliable Oct. 17th -- Preorders start Sept. 19th
Re: Best Buy offer $200 gift card with preorder
Yea I'm thinking it will be a ding because under trade in amount it will most likely show that you received 200 since Samsung only gives you the difference up to 200.
Re: Just pre ordered Note 4 from Verizon and have a couple of ?
i have never been charged an activation fee. I pre-ordered the Note 4 yesterday and the activation is free.
I'm on sprint and people used to be able to transfer the ESN to the new device and avoid upgrade fees
From what I recall, Sprint upgrade fee is $36 if you get a subsidized phone. You can switch esn anytime on Sprint without cost, same as Verizon.
Of note, att upgrade fee is $40,and Verizon upgrade fee is $30.
Sent from my Verizon Samsung Galaxy Note 3
The Verizon rep asked if I would use my current sim card, I said yes. Will I still get a new card with the Note 4?
No, you won't. I always ask for a new SIM card excuse each time I have tried moving my current Verizon 4G SIM card to a new phone it has failed to activate and I have had to drive to a Verizon corporate store to get a new one.
You can probably just have them update your order to include one.. It will be no charge.
Sent from my SM-P605V using Tapatalk
Re: Galaxy Note 4 on Sprint.
I'm pretty sure you can still get the subsidized price if you're eligible for an upgrade.
Posted via my Galaxy Note 3
Re: Galaxy Note 4 to be released on October 4 - Price $899
Nope, the dimensions are different, and the Note 4 does not have a USB 3.0 plug.
So? USB 3.0 going to 2.0 means little for cases. If the dimensions were the same you could use a note 3 case with the note 4
Re: Can't pre-order on Verizon just yet...
Oh ok. What phone do you have now? I have the note 3 and my battery life isn't good at all.
I also have a Note 3. Just like any other phone, the battery isn't as good as the day it came out of the box, but I still get a full day out of it with light use and about 8-10 hours out of it with heavy use. But I also have a spare battery so I just swap out when I get home from work and I'm back at 100%.
I also have the Gear 2 so that helps that I'm not pulling the phone out every 10 minutes to look at my notifications. I love the watch and I'll be getting the Gear S when it comes out also.
That's what he was trying to say. With the USB difference, hence there's a change in the dimensions as the Note 3 Case is really built for Note 3. The charging outlet for USB 2.0 is smaller than USB 3.0
If all things were equal.... And the difference was just a 2.0 port instead you COULD use a note 3 case on a note 4.... The thing in the bottom doesn't actually go into the port so it wouldn't matter
Once I received my replacement note 3 using my old battery, it is actually getting better battery life than in recent months. Maybe it was starting from scratch again reinstalling all of my apps and changing the notification settings or maybe it was simply due to the fact I was getting better reception and the phone wasn't constantly searching anymore. I have always wondered if plugging it in 3-4 times a day would cause battery life issues down the road. So far, it hasn't.
Sent from my SM-N900V using Tapatalk
I took a liking to the Samsung Gear 2 watch at the store, will it work with the Note 4? Kinda pricey though.
Yes it will work. I have it now and I love it. The new Gear S will be out next month so you might wanna wait for that. It will be more expensive (I read about $389 or so) but that also means the Gear 2 might get a price drop at the same time.
The sizes are very close, so the cases might fit (gel type will have a better chance than the hard clip on one's. The ones that replace the back will not work at all), but remember: the Note 4 moved the speaker to the back. So you will have to cut a hole in the neck of the case. There is a second mic where the Note 3 speaker was at the bottom so it looks like that hole might line up with the case. And finally the Note 4's camera lens is bigger, lower on the back and the flash is separated from the lense do it is also moved father down.
In conclusion you might be able to make it work work done cutting, but as cheap as cases are I would just but the right one and include the old cases in the sale when I sell the Note 3.
The sizes are very close, so the cases might fit (gel type ephod have a better chance than the hard clip on one's. The ones that replace the back will not work at all), but remember: the Note 4 moved the speaker to the back. So you will have to cut a hole in the neck of the case. There is a second mic where the Note 3 speaker was at the bottom so it looks like that hole might line up with the case. And finally the Note 4's camera lens is bigger, lower on the back and the flash is separated from the lense do it is also moved father down.
I was stating hypotheticals here. If ALL was equal but the 3.0 to 2.0 ports the case for note 3 would work on the note 4. Obviously it isn't and thus probably not even an ideal fit
I have an old HTC touch Pro 2 and my current Samsung S3. Do you think that I can trade in my old HTC against the Samsung pre-order promotion and keep my S3 as a backup?
Ordered the Note 4 via ATT account yesterday...shipping Oct. 14th.
Replacing my GS4.
Question for those on AT&T, I have 4 lines on my account and none are qualified for an upgrade anytime soon
But if I buy the note 4 outright, ($825 currently), I don't have to worry about needing an upgrade availability, correct?
sent from my Galaxy Note 3 via Tapatalk
Correct. I'm not eligible til June 2016 and I just ordered via Best Buy outright last night.
Awesome. So glad to hear that.
Trying to decide if I want to pre-order it or just go in Friday Oct 17 to the store to buy it. .
Bonembud
