On CM9, lost 20% battery in 8hrs w/deep idle on. Can I do better?
6tr6tr
1,211
14
I installed CM9 and it has improved my battery over stock. However, not quite as much as I'd like. On stock, I typically lost about 30% overnight. With CM9, in three times of leaving it idle I've done a little better:
8hrs 2m: lost 20%
6hrs 25m: lost 18%
9hrs 49m: lost 26%
Other than deep idle, what other settings can really help improve battery life? Using conservative governor? A different kernel? Something else?
Re: On CM9, lost 20% battery in 8hrs w/deep idle on. Can I do bet
Thanks. I've seen others suggest turning off wifi as well. A few questions:
1. Won't this make any background apps like Exchange run on 3G radio? Isn't that radio a bigger battery drain?
(And I can't seem to turn off Email's exchange checking. I've set it to Never, but it still keeps checking exchange accounts!)
2. Are there any issues with any apps from turning off wifi during sleep?
Also, are there any optimizations I can do to help improve battery life during usage? (I have the screen at 5% brightness)
You can disable data entirely by enabling airplane mode from the power menu. Or just data from settings
Sent from my Nexus S 4G using Tapatalk 2
Airplane mode means I won't get calls, emails, etc. That's not an option. Aside from that, the phone should do better than it is while essentially idling all night.
Get SetCPU and setup a "screen off" profile.
Leave your WiFi on.
Leave your WiFi on.
just out of curiosity, how is this different than deep idle? Doesn't deep idle basically set the cpu really low (to 100?) when the screen is off?
1. try tip 3 from my guide http://forums.androidcentral.com/general-help-how/193086-how-improve-battery-life-tips-tricks.html
2. Nope, not that i know off.. my wifi go to deep sleep and switch itself off at night... I havent had any issues yet.
screen takes up a lot of juice when in use... setting the brightness to low will increase battery life by a lot.
my wifi NEVER turns off; even when it is set to during sleep...
its a setting in Settings-->Wifi-->menu-->Advanced-->[keep wifi on during sleep]
It should sleep but it wont sleep right away.
5% is pretty damn low. Trust me, it's barely visible. And it's lower than the 0% in stock Android.
I have no idea how to save battery when in use apart from the screen brightness..
Hopefully someone else can post it here.
Yep, I'm hoping for other suggestions.
Has anyone used "conservative governor"? How well does it work?
