One-Click Root for Stock Gingerbread (Droid X, Droid 3, Droid X2,
Re: One-Click Root for Stock Gingerbread (Droid X, Droid 3, Droid
I rooted my DroidX last night and it worked great as a hotspot. When I tried to use the hotspot today it brings me to the VZW website asking me to activate it for $20. I rooted it again today and still the same result. Any suggestions or help?
I think I am gonna do this over my thanksgiving break. I keep getting heckled because I am an Android fan with an unrooted Droid X. This will shut them up. How long til ICS on Droid X or should I just get Galaxy Nexus Off Contract?
Will this work on droid pro?
I just wanted to make a quick post that this was successful on my Droid X2 running Gingerbread. Performed root using Win7 64-bit Ultimate
Phone: Android Version- 2.3.4
System Version- 1.3.380.MB870.Verizon.en.US
This was my first time rooting this phone, no problems. Thanks for the info guys!
the updated program worked great on .605/ 2.3.3 ..i was rooted running tranq 3.7.0 just went back to stock .340 to get 605 update rooted again within 5 minutes :D :D :D
Newb here, Reading all this info is gr8,i'm really going to try to root my DX today. One question,I have the 2.3.3 update with 4.5.605 update,i noticed that this is for the 602 update, will this still work for my DX. Never attempted rooting before due to me not knowing what i'm doing. I really like to get the DX hot spot going, then later on try to rid my DX of all the apps that came from verizon.Thanks for all your help
Thanks for your you tube vid really helps.Haven't tried yet but when i get the guts up i will.
how do you find out if it took. is there a new icon or what?
Look for the Superuser apk after getting your ROM or once youve rooted your stock device:
Grab Terminal Emulator from the Market
Open it and type su
if you get this...# youre rooted(#=superuser)
Does this work on the .605 Gingerbread? If not, can I sbf back to .602 from .605?
Edit: I read on a different thread that it should, so I will be giving it a whirl tonight then.
Edit 2: Worked like a charm!
DX GB 605 not able to get One C,ick to work, when I open Pete's motorola root tool file .exe or the Droid easy root .sh they all open as plain text with NOTHING happening.
Using Macbook with Lion
HELP:(
Trying this on my droid x running 4.5.621 and I get the following error:
Running exploit [part 2 of 3]?
Failed on ?/data/local.prop? ? Permission denied
Cannot create /data/local.prop: permission denied
?Repeats?
Then Reboots the phone
Running exploit [part 3 of 3]?
Remount failed: Operation not permitted
Failed to copy ?busybox? to /system/xbin/busybox?: Read-only file system
Su? and Superuser.apk
Unable to chmod /system/xbin/su: No such file of directory
what is happening?
?Repeats?
what is happening?
.621 is not rootable for the moment. You cannot SBF back to an earlier release. You're stuck unfortunately until somebody finds a way to root .621. Sorry :(
Droid X ver. 2.3
I ran the program but after reboot on set 2 I got the message:
cannot create /data/local.prop: permission denied
I followed all instructions and activated USB debugging what else do I need to do?
I've tried different links, multiple times, nothing works, some say "success" and still no Superuser on the phone. Others show error messages, but still aren't helpful. I am very VERY new to this whole rooting thing, but had no problem rooting Droid Razr, but cannot root my Droid X for the life of me. This is the latest that I tried and the message received:
failed to copy 'busybox', 'su', 'superuser.apk' to /system
Unable to chmod /system...
Please help!
Please help!
Try this
How to Root Your Droid X Running Android 2.3 Gingerbread
Is there anywhere else to get Droid 3 easy root script v7? The page it is linked to says the file is unavailable due to TOS violation. Going to head over to XDA but thought I'd ask. Thanks
Arwen
