OnePlus 3 Maintenance Update - sRGB & RAM Management
Re: Software update 3.2.0 rolling out.
Been using it a couple hours now. So far no problems. I do prefer the srgb setting since I always found the screen too blue.
If you want it quicker download "Free VPN proxy by Snap VPN" from the play store and connect to
Germany then check for the update. You can disconnect from the VPN as soon as you start the download.
Thanks but I'll wait it out. Gives me a chance to see what if any bugs exists before hand. Lol. They say within 48 hrs everyone should have it so it won't be long.
Update:[FONT=&quot] OnePlus has halted the update for the OnePlus 3. The company is citing reports of issues while upgrading, so the update will not be available while it investigates. We will provide additional details as they become available.
[/FONT]
http://www.androidcentral.com/oxygenos-320-now-available-oneplus-3-ram-management-fixes-and-more
My update failed three times. Had to unlock it and put twrp on it then download the ROM and update that way. It was fine after the update. Been running smooth so far.
Wouldn't mind knowing what the issue was seeing as I got tired of waiting and flashed the zip.
Seems to be running OK though, and sRGB does seem to look better...
Disappointing to see June as the security patch level though.
I believe the issue was people with SIP accounts were having their dual Sims not recognized. They pulled it it looks like to fix the issue. To many people had issues.
I have two one plus 3. One with 3.1.3 which updated fine. 3.1.2 however would fail during install.
Cool, don't use SIP.
Saw people were having trouble on their forum, but didn't realise it was a big enough issue to pull the update.
Just downloaded 3.2.1
Same update as 3.2.0 but they added a fix for those who were having SIM card issues. So far no issues.
I do have a new VOLTE icon on the status bar. No sim issues. I'll have to see how battery life fares. Nice to see OnePlus updating their devices.
Re: Just downloaded 3.2.1
Cool, good that they fixed it so quickly.
I assume it's still using the June security patch?
Boo :( Personally I would've preferred to wait a week for 3.2 with July's patch, hopefully we'll get updated again before too long.
3.2.1 needed to be quick though, i haven't noticed any problem, but i presume if you actually use SIP the issue is crippling.
Just installed it to. Hopefully it works well this time although I didn't have issues before personally.
Just installed it here. Used a VPN to Germany and got it immediately! So far so good! No issues and it's buttery smooth!
dmflowsjalallodhi
