optimus g pro 5.5 inch how big realy then normal
Chinmay Panda
7
I am now confused between optimus g and g pro because of the screen size difference.
2. i want a device for my daily use.does it get comfertable on my daily use
3. do i need to take extra care of it?is it gets handy to every where
Re: 5.5 inch how big realy
Depends on how big your hands are. The pro is a largish phone. But the screen is great and so is the standby battery life.
Sent from my LG-E980 using Tapatalk 4
But i heard about g2 is coming with some more exitements.Any idea about g2 features
Faster processor, different button location, no SD card slot. Screen is smaller by 0.3 inches.
Honestly, you'll have to hold one. That's the only way to know if it's going to be comfortable. It's a little smaller than the Galaxy Note series, same screen size but smaller bezel. Now that I'm used to it, I find even a 5" screen feels small. But different people are comfortable with different phone sizes.
As far as extra care, well, it is a larger screen and a narrow bezel, but few phones do well if they are dropped. A case is highly recommended.
Well. More than that because they have the android on screen buttons and that takes up even more screen. So in reality the G2 will be more like 4.9"-5.0".
