Optimus S Rooting Issues
Getting back to ZVD should be possible by KP500, you can do this and Gingerbreak by PC.
Just curious, where did you store the ZVJ update.zip in order to upgrade? I thought this had to be on /sdcard to flash by stock recovery?
/cache and bad sdcard reader
If time allows tonight I'll try to flash my phone back to stock KP500, root with Gingerbreak and then try these steps without using the MicroSD card to see what happens.
KP500 keeps force closing in Windows XP SP3. X86 . Get as far as 100% extracting the cab when the ERROR message telling me to send a error report comes on.
Hey rnorris have thou tryed bending the pins on the sd card reader in some my wifes stoped working and that fixed it
Sent with telepathic powers
Can you post the log from the updater tool if there is one?
It said it completed sucessfully, but I'm still Gingerhell.
But here's the log:
07:41:17 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
07:41:17 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
07:41:17 : Start Date : 2012-04-13 07:41:17
07:41:17 : -------- Buyer Test mode ---------
07:41:17 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
07:41:17 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
07:41:18 : *****CheckOS Start********
07:41:18 : Microsoft_Windows_X07:41:18 : PCSyncPrograms Not Found
07:41:18 : SetEmerModeAT()
07:41:18 : _IsConnectedPhone Call
P_Professional_07:41:18 : _IsConnectedPhone(0)
07:41:19 : 0 - NotConnected.
07:41:19 : 1 - Normal connect success
07:41:19 : 2 - Emergency connect success
07:41:40 : Checking the connection with the cell phone...
07:41:40 : dwWaitResetTime(40000 ms)
07:41:41 : _IsConnectedPhone Call
07:41:41 : _IsConnectedPhone(0)
07:41:41 : 0 - NotConnected.
07:41:41 : 1 - Normal connect success
07:41:41 : 2 - Emergency connect success
07:41:42 : _IsConnectedPhone Call
07:41:42 : _IsConnectedPhone(0)
07:41:42 : 0 - NotConnected.
07:41:42 : 1 - Normal connect success
07:41:42 : 2 - Emergency connect success
07:41:44 : _IsConnectedPhone Call
07:41:44 : _IsConnectedPhone(0)
07:41:44 : 0 - NotConnected.
07:41:44 : 1 - Normal connect success
07:41:44 : 2 - Emergency connect success
07:41:44 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
07:42:39 : _IsConnectedPhone Call
07:42:39 : _IsConnectedPhone(0)
07:42:39 : 0 - NotConnected.
07:42:39 : 1 - Normal connect success
07:42:39 : 2 - Emergency connect success
07:42:39 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
07:43:09 : _IsConnectedPhone Call
07:43:09 : _IsConnectedPhone(0)
07:43:09 : 0 - NotConnected.
07:43:10 : 1 - Normal connect success
07:43:10 : 2 - Emergency connect success
07:43:10 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
07:43:26 : _IsConnectedPhone Call
07:43:32 : _IsConnectedPhone(1)
07:43:32 : 0 - NotConnected.
07:43:32 : 1 - Normal connect success
07:43:32 : 2 - Emergency connect success
07:43:32 : Phone Mode(1)
07:43:32 : *****GetPhoneType Start*****
07:43:35 : Phone Type : CDMA
07:43:35 : *****Start GetPreviousStep*****
07:43:35 : _GetPreviousStep(dwStep:0xffff)
07:43:35 : _SetPhoneNumber retval=1
07:43:35 : *****GetPhoneModel Start*****
07:43:37 : *****GetPhoneBinaryVersion Start*****
07:43:38 : Phone Bin Version : LS670ZVJ_05
07:43:38 : *****Get ESN / IMEI / MEID Start*****07:43:44 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000023358083, Model :
07:43:44 : *******CheckBinVersion***************
07:43:45 : New Bin Version(LS670_ZVD), Current Ver(LS670ZVJ_05)
07:43:45 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.07:43:53 : _SetAuthMark Ok : wAuthMark(17066), PhoneMode(1)
07:43:53 : *****Start _GetBatteryLevel*****
07:43:56 : Battery(5)
07:43:57 : ResetPhone...
07:43:57 : Checking the connection with the cell phone...
07:43:57 : dwWaitResetTime(40000 ms)
07:43:47 : _GetAuthMark : wAuthMark(17066)
07:43:47 : Wait 3Sec
07:44:27 : _IsConnectedPhone Call
07:43:40 : ESN/IMEI/MEID : A0000023358083
07:43:40 : *****GetPhoneNumber Start*****
07:43:43 : Phone Number : A0000023358083
07:41:18 : *****CheckPCSyncPrograms Start*****
07:44:33 : _IsConnectedPhone(1)
07:44:33 : 0 - NotConnected.
07:44:33 : 1 - Normal connect success
07:44:33 : 2 - Emergency connect success
07:44:33 : Phone Mode(1)07:45:04 : _IsConnectedPhone Call
07:45:09 : _IsConnectedPhone(1)
07:45:09 : 0 - NotConnected.
07:45:09 : 1 - Normal connect success
07:45:09 : 2 - Emergency connect success
07:45:09 : Phone Mode(1)
07:45:10 : Call _ModeOffline()
07:45:11 : *****CheckPCSyncPrograms Start*****
07:45:11 : PCSyncPrograms Not Found
07:45:12 : CLGMobileHttp Class ?Ҹ????.
07:45:12 : CLGMobileHttp Class ?Ҹ?...
07:45:13 : ****************CheckAndDownload********************
07:45:13 : ******Extract Start LS670ZVD.cab*****
07:45:13 : Model Dll Dir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
07:44:33 : m_dwBootWaitTime(36312)
07:44:33 : Checking the connection with the cell phone...
07:44:33 : dwWaitResetTime(30000 ms)
07:45:36 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZVD_12.S12.P60675.wdb\n
07:45:37 : WDB(or DZ) FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZVD_12.S12.P60675.wdb)
07:45:37 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_3_0.dll\n
07:45:37 : Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_3_0.dll)
07:45:37 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZVD_12.S12.P60675.wdh\n
07:45:37 : NNNNN WDB FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZVD_12.S12.P60675.wdb)
07:45:37 : NNNNN Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_3_0.dll)
07:45:37 : Extract End LS670ZVD.cab
07:45:38 : *****WorkModelDLL Start*****
07:45:41 : strPhoneBinaryPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZVD_12.S12.P60675.wdb)
07:45:41 : strModuleDir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
07:45:41 : strModelDLLPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_3_0.dll)
07:45:41 : m_nPhoneMode(1)
07:45:42 : Phone mode 1 = Normal
07:45:42 : Phone mode 2 = Emergency
07:45:42 : Phone mode 4 = CSE
07:45:42 : _DetachDLL Call
07:45:42 : _DetachDLL Call End
07:45:42 : Call fn_StartUpgrade
07:45:42 : ### Start Upgrade - CDMA ###
07:45:42 : ********* CDMA Model.dll input Parameter *************
07:45:42 : MODEL_EVENT : 32769
07:45:42 : PhoneBinaryPath : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZVD_12.S12.P60675.wdb
07:45:42 : ModuleDir : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\
07:45:43 : BootWaitTime : 54468
07:45:43 : UsbHighSpeed : FALSE
07:45:43 : PhoneMode : 1
07:45:43 : NewPhoneBinVersion : LS670_ZVD
07:45:43 : ClearSI : FALSE
07:45:43 : AuthMark : 17066
07:45:43 : ********* CDMA Model.dll input Parameter End*************
07:45:44 : wParam : 20, lParam = 570
07:45:44 : MODEL DLL Event : (20, 570)
07:45:45 : Model Dll Msg Not Found(20, 570)
07:47:33 : wParam : 4, lParam = 0
07:47:33 : MODEL DLL Event : (4, 0)
07:47:45 : wParam : 5, lParam = 1
07:47:45 : MODEL DLL Event : (5, 1)
07:47:46 : wParam : 5, lParam = 0
07:47:50 : wParam : 5, lParam = 1
07:47:54 : wParam : 5, lParam = 2
07:47:57 : wParam : 5, lParam = 3
07:48:01 : wParam : 5, lParam = 4
07:48:05 : wParam : 5, lParam = 5
07:48:09 : wParam : 5, lParam = 6
07:48:13 : wParam : 5, lParam = 7
07:48:17 : wParam : 5, lParam = 8
07:48:21 : wParam : 5, lParam = 9
07:48:25 : wParam : 20, lParam = 516
07:48:25 : MODEL DLL Event : (20, 516)
07:48:25 : Model Dll Msg Not Found(20, 516)
07:48:25 : wParam : 5, lParam = 10
07:48:29 : wParam : 5, lParam = 11
07:48:33 : wParam : 5, lParam = 12
07:48:37 : wParam : 5, lParam = 13
07:48:41 : wParam : 5, lParam = 14
07:48:45 : wParam : 5, lParam = 15
07:48:49 : wParam : 5, lParam = 16
07:48:53 : wParam : 5, lParam = 17
07:48:57 : wParam : 5, lParam = 18
07:49:01 : wParam : 5, lParam = 19
07:49:05 : wParam : 5, lParam = 20
07:49:08 : wParam : 5, lParam = 21
07:49:12 : wParam : 5, lParam = 22
07:49:16 : wParam : 5, lParam = 23
07:49:20 : wParam : 5, lParam = 24
07:49:24 : wParam : 5, lParam = 25
07:49:28 : wParam : 5, lParam = 26
07:49:32 : wParam : 5, lParam = 27
07:49:36 : wParam : 5, lParam = 28
07:49:40 : wParam : 5, lParam = 29
07:49:44 : wParam : 20, lParam = 440
07:49:44 : MODEL DLL Event : (20, 440)
07:49:44 : Model Dll Msg Not Found(20, 440)
07:49:44 : wParam : 5, lParam = 30
07:49:48 : wParam : 5, lParam = 31
07:49:52 : wParam : 5, lParam = 32
07:49:56 : wParam : 5, lParam = 33
07:50:00 : wParam : 5, lParam = 34
07:50:04 : wParam : 5, lParam = 35
07:50:08 : wParam : 5, lParam = 36
07:50:12 : wParam : 5, lParam = 37
07:50:15 : wParam : 5, lParam = 38
07:50:19 : wParam : 5, lParam = 39
07:50:23 : wParam : 5, lParam = 40
07:50:27 : wParam : 5, lParam = 41
07:50:31 : wParam : 5, lParam = 42
07:50:35 : wParam : 5, lParam = 43
07:50:39 : wParam : 5, lParam = 44
07:50:43 : wParam : 5, lParam = 45
07:50:47 : wParam : 5, lParam = 46
07:50:51 : wParam : 5, lParam = 47
07:50:55 : wParam : 5, lParam = 48
07:50:58 : wParam : 5, lParam = 49
07:51:02 : wParam : 5, lParam = 50
07:51:02 : wParam : 20, lParam = 362
07:51:03 : MODEL DLL Event : (20, 362)
07:51:03 : Model Dll Msg Not Found(20, 362)
07:51:03 : wParam : 5, lParam = 50
07:51:07 : wParam : 5, lParam = 51
07:51:11 : wParam : 5, lParam = 52
07:51:15 : wParam : 5, lParam = 53
07:51:19 : wParam : 5, lParam = 54
07:51:23 : wParam : 5, lParam = 55
07:51:27 : wParam : 5, lParam = 56
07:51:31 : wParam : 5, lParam = 57
07:51:34 : wParam : 5, lParam = 58
07:51:38 : wParam : 5, lParam = 59
07:51:42 : wParam : 5, lParam = 60
07:51:46 : wParam : 5, lParam = 61
07:51:50 : wParam : 5, lParam = 62
07:51:54 : wParam : 5, lParam = 63
07:51:58 : wParam : 5, lParam = 64
07:52:02 : wParam : 5, lParam = 65
07:52:06 : wParam : 5, lParam = 66
07:52:10 : wParam : 5, lParam = 67
07:52:14 : wParam : 5, lParam = 68
07:52:18 : wParam : 5, lParam = 69
07:52:22 : wParam : 20, lParam = 283
07:52:22 : MODEL DLL Event : (20, 283)
07:52:23 : Model Dll Msg Not Found(20, 283)
07:52:23 : wParam : 5, lParam = 70
07:52:27 : wParam : 5, lParam = 71
07:52:31 : wParam : 5, lParam = 72
07:52:35 : wParam : 5, lParam = 73
07:52:39 : wParam : 5, lParam = 74
07:52:43 : wParam : 5, lParam = 75
07:52:47 : wParam : 5, lParam = 76
07:52:51 : wParam : 5, lParam = 77
07:52:56 : wParam : 5, lParam = 78
07:53:00 : wParam : 5, lParam = 79
07:53:03 : wParam : 5, lParam = 80
07:53:07 : wParam : 5, lParam = 81
07:53:10 : wParam : 5, lParam = 82
07:53:14 : wParam : 5, lParam = 83
07:53:17 : wParam : 5, lParam = 84
07:53:22 : wParam : 5, lParam = 85
07:53:25 : wParam : 5, lParam = 86
07:53:30 : wParam : 5, lParam = 87
07:53:34 : wParam : 5, lParam = 88
07:53:38 : wParam : 5, lParam = 89
07:53:42 : wParam : 5, lParam = 90
07:53:46 : wParam : 5, lParam = 91
07:53:50 : wParam : 5, lParam = 92
07:53:54 : wParam : 5, lParam = 93
07:53:58 : wParam : 5, lParam = 94
07:54:02 : wParam : 5, lParam = 95
07:54:06 : wParam : 5, lParam = 96
07:54:10 : wParam : 5, lParam = 97
07:54:14 : wParam : 5, lParam = 98
07:54:17 : wParam : 5, lParam = 99
07:54:21 : wParam : 5, lParam = 100
07:54:21 : wParam : 6, lParam = 0
07:54:22 : MODEL DLL Event : (6, 0)
07:54:50 : wParam : 20, lParam = 110
07:54:50 : MODEL DLL Event : (20, 110)
07:54:50 : Model Dll Msg Not Found(20, 110)
07:54:50 : wParam : 8, lParam = 0
07:54:50 : MODEL DLL Event : (8, 0)
07:55:49 : wParam : 10, lParam = 1
07:55:49 : MODEL DLL Event : (10, 1)
07:55:49 : wParam : 10, lParam = 2
07:55:49 : wParam : 10, lParam = 4
07:55:49 : wParam : 10, lParam = 6
07:55:49 : wParam : 10, lParam = 8
07:55:49 : wParam : 10, lParam = 10
07:55:49 : wParam : 10, lParam = 12
07:55:49 : wParam : 10, lParam = 14
07:55:49 : wParam : 10, lParam = 16
07:55:50 : wParam : 10, lParam = 18
07:55:50 : wParam : 10, lParam = 20
07:55:50 : wParam : 10, lParam = 22
07:55:50 : wParam : 10, lParam = 24
07:55:50 : wParam : 10, lParam = 26
07:55:50 : wParam : 10, lParam = 28
07:55:50 : wParam : 10, lParam = 30
07:55:50 : wParam : 10, lParam = 32
07:55:50 : wParam : 10, lParam = 34
07:55:50 : wParam : 10, lParam = 36
07:55:51 : wParam : 10, lParam = 38
07:55:51 : wParam : 10, lParam = 40
07:55:51 : wParam : 10, lParam = 42
07:55:51 : wParam : 10, lParam = 44
07:55:51 : wParam : 10, lParam = 46
07:55:51 : wParam : 10, lParam = 48
07:55:51 : wParam : 10, lParam = 50
07:55:51 : wParam : 10, lParam = 52
07:55:51 : wParam : 10, lParam = 54
07:55:51 : wParam : 10, lParam = 56
07:55:52 : wParam : 10, lParam = 58
07:55:52 : wParam : 10, lParam = 60
07:55:52 : wParam : 10, lParam = 62
07:55:52 : wParam : 10, lParam = 64
07:55:52 : wParam : 10, lParam = 66
07:55:52 : wParam : 10, lParam = 68
07:55:52 : wParam : 10, lParam = 70
07:55:52 : wParam : 10, lParam = 72
07:55:52 : wParam : 10, lParam = 74
07:55:52 : wParam : 10, lParam = 76
07:55:53 : wParam : 10, lParam = 78
07:55:53 : wParam : 10, lParam = 80
07:55:53 : wParam : 10, lParam = 82
07:55:53 : wParam : 10, lParam = 84
07:55:53 : wParam : 10, lParam = 86
07:55:53 : wParam : 10, lParam = 88
07:55:53 : wParam : 10, lParam = 90
07:55:53 : wParam : 10, lParam = 92
07:55:53 : wParam : 10, lParam = 94
07:55:53 : wParam : 10, lParam = 96
07:55:54 : wParam : 10, lParam = 98
07:55:54 : wParam : 10, lParam = 100
07:55:54 : wParam : 20, lParam = 0
07:55:54 : MODEL DLL Event : (20, 0)
07:55:55 : Model Dll Msg Not Found(20, 0)
07:55:55 : wParam : 12, lParam = 1
07:55:55 : MODEL DLL Event : (12, 1)
07:55:55 : CLGMobileHttp Class ?Ҹ????.
07:55:55 : CLGMobileHttp Class ?Ҹ?...
07:55:56 : CleanModelDll() : Free Model.dll
07:55:56 : _DetachDLL Call
07:55:56 : _DetachDLL Call End
07:55:56 : FreeLibrary Call
07:55:58 : FreeLibrary Call End
07:56:00 : Step : S/W Upgrade Complete!
07:58:11 : =======Cancel button click : m_nStep(9)
07:58:11 : http://csmg.lgmobile.com:9002/csmg/...n=Y&phone_no=A0000023358083&receivephone_yn=N
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
07:58:12 : RemoveDirectory1 Error(145):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\BIN
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\CAL] ???丮 ???? ?õ?
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\NVMeta] ???丮 ???? ?õ?
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\PRL] ???丮 ???? ?õ?
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\SCR] ???丮 ???? ?õ?
07:58:12 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
07:58:13 : RemoveDirectory1 Error(145):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
07:58:13 : OnModelDllMsg delete m_pLGCyonUpdate
07:58:13 : CLGMobileUpdate Class ?Ҹ? ????...
07:58:13 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
07:58:13 : RemoveDirectory1 Error(145):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\BIN
07:58:13 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
07:58:13 : CLGMobileUpdate Class ?Ҹ?...
07:58:13 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
07:58:13 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
Yeah, the logs do say it was successful. I'm a little surprised it can flash successfully and you still are on Gingerbread.
I got it rooted with your script (optiauto) but with a few minor changes in the script. Of course I gave credit to you in the RUNFIRST bat, so can I post the file so others like me can use it? :D
