- May 23, 2013
- 8
- 0
- 0
I know that MF3 is having some flash problems so i can't flash the stock rom because i already tried with 2 different stocks rom. I also already tried to use the custom pit files that were used to fix the bootlop issue with kies or whatever (adonis.pit, MF3_BTL_FIX and SGS_I337_16GB), which came out with no luck.
Is there a way to flash the stock rom on MF3?
EDIT:I might as well post the fix here as well...
After just playing around with odin.
I think i have found a fix.
Flash this http://downloads.fairview5.com/i337/...ipe.tar.md5.7z through odin and it should go through if you're on MF3
Then i used the pit file called "SGS-I337_16GB.pit" idk where it is but it's on the forums (I never tested if you needed it or not, i put it there in case i did need it. If someone would test if you do or don't need, that would be awesome
Note:This will upgrade your phone to 4.3 and there are no root methods for 4.3 as of right now.Plus there might be some problems with the playstore.(i haven't encounter any yet)
Also remember that you can go to BestBuy and ask them to flash your phone in-case you want to stay on 4.2.2 MF3(god knows why you would want to). This is for people who just want to fix it now instead of going to a store.
Credit to jball, rayburne for telling me to put the downsides and other options.
And to upndwn4par for releasing MJ6 to the public.
EDIT2: Someone found a better method for the MF3 recovery fix incase you want to stay on 4.2.2 and still root it. I'll post the link here:http://forum.xda-developers.com/showthread.php?p=46901199#post46901199
