OTA Verizon Site change?? OTA today??
Let the "I havent gotten the update yet," and the "Post your location so we can see if it is rolling out by geography," and the "when did you buy yours" threads and posts now begin along with the "what if I am rooted!" thread
Where are you located? I didn't get my update yet?!?! WTF?!?! :)
Its not the same build number as the leaked MR2 update....it has been tweaked a few times since it was leaked....and yes you will be fine.
Thanks. Just a little wary... I'm use to updates being a good thing from my old, reliable droid1 ! This TB and related business is so buggy...
Based on the AC front page describing what is included in this update I may pass on it until others comment on the experience. I'm one of the lucky ones. My Bolt does not shutdown nor reboot. Went 164 hours until I manually reset it last week. My GPS locks in 5-10 seconds normally. If it doesn't, a quick flush/reload via "GPS Status" and all is well again. Was really hoping this would be Gingerbread but I'm very happy with my Bolt so far so I'll be patient.
Does anyone besides me think that we're only gonna get this because we're still getting hotspot sharing for free?
Sent from my Thunderbolt via Tapatalk
I doubt it, a lot of us are no longer getting it for free without the update.
I just checked and got Service unavailable, then an Error:2304 :mad:
Edit: Bought mine on day one - Live in 4G Ohio
I agree, I'll check for the update - but I ain't trying it until others do.
For the past 3 days when I check for and update it says it's checking then says nothing at all. Doesn't give me errors, doesn't say no updates available, nothing. Just shows the checking for update screen which then disappears back to the update screen. Restarted the phone to no avail.
I love how it says " Reduced number of device power cycles and resets."
Define reduced, I think STOP or resolved would have been better idea to focus on!
Yeah that's exactly what I thought
Sent from my ADR6400L using Tapatalk
A lot of us have reported the same thing and I still haven't found out why.
So this is coming out today, right? I just have a couple of comments/questions:
I havent gotten the update yet.
Post your location so we can see if it is rolling out by geography.
When did you buy yours?
None of this makes any difference what order you get the update in. It's completely random.
What if I am rooted?
It would be best to un-root and revers any changes you have made to your system since rooting as this will reduce the likelihood of a problem with the update. You WILL loose toot once you apply this patch anyway.
cinemacritic
