Overclocked Kernel for ZVD
So for some reason zvd won't compile but I again compiled a zvi kernel overclockable to 1.4 GHz I just don't have a clue how to get it on my phone to test
Sent from my LG-LS840 using Android Central Forums
How stable though? 1.2 to 1.8 is a pretty big jump
DANNY! BY GEORGE I THINK I GOT IT!:P the zvd is compiling no errors and I set the menuconfig to max over clock of 1.78 GHz if everything goes well I should have a zimage in 45 mins or so
SWEET THAT IS AWESOME
Do you think it will be able to over clock just by changing the menuconfig it seems like it wouldn't be that easy
I actually have no clue but they wouldn't put it there if it didn't work
I hope so. My computer froze the first compile so I'm doing it again:p
It says its missing a file:/ zvd is just a no go :p
EFF zvd but I compiled the zvc kernel I tried swapping files between the 2 I just couldn't get it, but tomorrow I'll try and flash it the zvc kernel to zvd and see how it works I'd think it really shouldn't be that much of a different between the two.
Cant overclock it the menuconfig doesnt work and i lost wifi
but i did compile zvd and flashed it to my phone:P
tar xvfz <source>
mkdir -p out
make <defconfig> ARCH=arm CROSS_COMPILE=<arm source> O=out
make <menuconfig> ARCH=arm CROSS_COMPILE=<arm source> O=out
[i have a dual core pc so...]
make -j3 zImage ARCH=arm CROSS_COMPILE=<arm source> O=out
Abheetha Athukorala
