Overclocking Settings Help
alphabets
729
3
i am looking for the best combo of speed and battery life...more leaning towards battery life because i feel as tho the X is pretty quick the way it is. i am Z4 rooted, with the following root apps installed:
Droid X Bootstrapper
DX/D2 Overclocker
Minfreemanager
Titanium Backup
SetCPU
i am looking for the best combo of settings between overclocker, setpcu, and minfreemamnager. or do i even need minfree?
any tips of settings would be great!
thank you!
In overclock app try the stock undervolt and then set profiles in setcpu. One to min cpu when screen is off and another when battery is low drop cpu. That's for great battery. I ran 1.2 and then undervolted it as a custom setting with same setcpu and that was fast and battery was good.
Sent from my DROIDX using Tapatalk
Ok...but what would the undervolt number be?
Just select "LowVoltage 1GHZ" like TnT said in your dx overclocking app.
The actual vsels will be displayed at the bottom after your selection.
ok, from the preset low voltage setting, i cannot increase my Ghz to 1.2. so im guessing i can then just customize the 1.2 preset to the low volt vsels setting correct?
basically i want 1.2Ghz with the low volt.
Mine is very stable at the following custom settings:
Max vsel: 63
Max Clock: 1.2
slot one: 300000/26
slot two: 700000/38
slot three: 1000000/56
slot one: 1200000/63
You could but I don't think it'll take. At those low settings and trying to get 1.2 .........not a good mix,
but if you can get that I'll buy you a case a beer dude!
Good Luck!
Good Luck!
haha, ok. i was under the impression that i could up my Ghz and lower my voltage to increase my speed yet sve battery life. ill just keep searching settings and see what has been the best combo for people. thanks.
