P30 Pro 256, notifications problems
  • Start date Start date
A
Android Central Question
Impossible to have Teams notifications. All possible settings are on according to Huawei support instructions. Battery settings also check. Viber calls same problem.
Can't enable wallet, same wallet with same sim card and same Provider was working fine in P20 Pro
Hello
It's new, all these problems are day one
My previous device was a P20 Pro
I had SOME problems with MS Teams notifications.
Non with viber and wallet was working fine.
I switched the sim card and clone old phone here.
Read all about, remove and reinstall apps, open every known setting, took phone guidance from Huawei support but nothing worked.
Thanks in advance
Hello
Thanks in advance
Something to my non expert mind remarkable. Was watching the running apps and I noticed MS Teams appear in list and vanish after a second and again and again...
BekaH
