Package disabler
Use good lock module Home up
Share menu View attachment 352149
Sent from my SM-S918U1 using AC Forums mobile app
Most of that stuff is done in the edit section of share panel now. It still does not let you remove apps you don't want to use for sharing. So far the only way I see to remove Samsung messages from the list is to disable it thru package disabler. So far the only negative don't that is using direct messages on task edge panel. Thanks, any suggestion is welcome
Sent from my SM-X800 using Tapatalk
This is in good lock.. The only contacts it will let me select is Samsung messages. It does nothing else, Google messages is not an option in good lock.
This is in my tablet 8+. On my phone they are there. I'm guessing since it's the tablet Samsung is only showing Samsung messages???
Do you guys use this app for all Samsung device?.
Any performance increase?. I can't find it on app store.
Sent from my SM-S918U1 using Tapatalk
Ahh on the tablet I'm not sure
Good lock ? Yes use it on all Samsung for increase performance no
No, I meant package disabler pro. This phone packed with great hardware so I'm not sure if we needs extra juice.
It's for bloat u don't want but performance I haven't noticed.
I disable digital wellbeing, tips and tricks etc..
Depends if there things you want to block. I block Bixby stuff, I block Samsung messages to keep it out of my share box when sharing, I also block OS software updates until I see if there's no issues from the ones in here that get giddy for the updates and can't wait to get them, they are my guinea pigs.
cinemacritic
