[Patch] Virgin Mobile VM9 Radio Update - Removed.
Status
Not open for further replies.
Re: [Patch] Virgin Mobile VM9 Radio Update
waiiit a second will they throttle me with this? if so i dont want it!
This update bricked my phone and its refusing to go past the LG logo, any suggestions on what to do now?
I flashed this radio update in recovery, my phone went blank, and now its only showing the LG logo and it wont go to recovery or anywhere...
I used the Touch recovery....Anyone have any suggestions on how to unbrick my phone because of this?
Which recovery were you using? And what rom?
Very important before I flash
Is this compatible with IHO BACKside?
The rom you used doesn't matter. It has nothing to do with the radio since its not being placed within the system partition
Reactions: Badboytoast
Try pulling the battery out and leave it like that for like an hour then put the battery back on and power the phone on!! Just power on, not into recovery
phone wont go past lg either !! used the touch recovery also ! :O
i flashed it before i read those comments anyone found a way to fix it ?
F'ing touch recoveries.
Do NOT FLASH WITH TOUCH RECOVERY or MutiRom Recovery!
Similar happened on the Evo with touch recovery. Bricked phones.
It's not the patch bricking your phone, it's that recovery not liking the patch.
The patch works fine on Bobzhome, IHO and Xionia.
Status
Heritagesa01
