[Patch] Virgin Mobile VM9 Radio Update - Removed.
Status
Not open for further replies.
Source code!!!!!
Sent from my VM670 using Tapatalk 2
Re: [Patch] Virgin Mobile VM9 Radio Update - Restored!
Sooooooo awesome! Tomorrow is going to be a busy day... :D
tomorrow? i'm starting right now!
edit: made a diff, it applied almost completely clean to my kernel. only things that didnt are ami304.c and .h
edit 2: compiling! thanks to leslieanne's build server, it should be done soon :D
edit 3: uploading...
edit 4: http://www.mediafire.com/?n1c1q159pr5nck1
edit 5: ami304.c and .h didnt apply because of a commit with the message "Update to Sprint's/Zefie's AMI304 driver." which.. already patched them
downloaded and flashed on a fresh install of backside. now for the waiting game :)
So, wait, you're saying nothing has changed?
Black Butte Porter. :)
Dechutes makes some great beers. If your ever back in the tri cities you have to let me buy you a beer at ice harbor brewery best beer ever. OK sorry to get off topic... so umm... how about that radio update!
Sent from my Galaxy Nexus using Tapatalk 2 Beta-5
edit 4: tvall_kernel_v0.3.1.zip
You gotta be careful with the AMI304 driver. They changed the ioctl api in a driver update, so the kernel driver and userspace need to match. I think that update was done with the Sprint GB release (but I'm not 100% sure).
I think I'll be down there week after next, actually. :) I'll PM you when I find out for sure.
If there isn't any difference in the code, what kind of an improvement we are expecting from this kernel source? :confused:
Edit for clarification for the others reading the thread: There is a difference, apparently, as TDM's diff shows later in the thread.
...and why is it breaking IHO for some of us, and the only fix being a different kernel?
Come to think of it, I'm moreso just asking for curiosity's sake now...I think I'll be sticking with ICS. :p
I was referring to the recent ZV9 kernel source from LG. The different kernels that you have seen improvement with are 2.6.35 Gingerbread kernel. This LG source is still the same 2.6.32.9 Froyo source we have been using with IHO.
In case there is a problem with the v3.7 kernel binary, I am testing the kernel binary which is built on my machine using the source from Bob's repo. I would appreciate if anybody can test and give feedback. I think I will use these binaries in the next MiRaGe build.
http://www.mediafire.com/?9ogmh5j5hqswxa6
MD5sum: E69FAF8FA222D06ACB4116C64DDCB893
PS: kernel binary updated with v3.7 source to be consistent and used gcc 4.7 instead of gcc 4.5
Edit: TDM's diff was done properly after tvall's diff and the differences are shown below.
I'll test it for you. Would you prefer I report back here, another thread, or a PM?
Sent from the BACKside of Tapatalk 2
Reactions: mrg666
You can post here or PM me. Whichever is easier for you. Thanks!
@mrg: thanks a lot. I'll test this later today. Do you have an MD5 for it? Small risk, I know. Just don't want to think I'm testing a new kernel when I'm actually testing a bad download ;)
Question: did you build it for a specific MiRaGe version?
Reactions: brotherswing
Looks like a flashable zip to me. Should work on any IHO build...
Correct me if I'm wrong
Here is the ZV9 kernel diff. 25kb instead of 125mb. ;)
Reactions: mrg666
Status
FahadsTech
