[Patch] Virgin Mobile VM9 Radio Update - Removed.
Status
Not open for further replies.
Holy !!!!
I think this finally fixed my ty internet speeds!!
Before I was getting this crap:
Now I got this:
What is "ty internet speeds"?
Re: [Patch] Virgin Mobile VM9 Radio Update - Restored!
@Leslieann when you say bobzhome recovery, do you mean Vm670nh or the other one? Ian confused? ?;( thanks
Bobzhome and VM670MH are the same.
People may think it to be dumb to go back to the Touch Recovery, but I did. It works well, have new had a problem and besides the camera button on my V is kind of weird.
Reactions: Badboytoast
Rom Manager + Radio Update = KABOOOOMMMM!!!!!!!!
Lol... why does rom manager manage to make its way into every thread.:p
Forsooth, in any threade of suffient length upon thyne here forumne, it shall come to paseth that types of three parlies with come about:
1. ROM Manager
2. Throttling/Virgin Mobile doth suck
3. Upon what time the clock shall read that ROM bugs wilst be fixed
:p
To the people that bricked there phone hold POWER + VOL DOWN + CAMERA + SEARCH, and it goes into emergency mode. Then use kdz to flash the zv8 firmware and it will revert your radio. Then make sure to root and flash the virgin recovery, rom and other files.
A good read
Thanks asadullah, I was searching all day for that post, my search-fu weak, your knowledge strong! ;)
A good read
He came out of retirement to help... what a guy!
Yeah, for me this radio update didn't really do much - same speeds, same voice quality.. just a moral side of it is I have the latest and the greatest... :cool:
I have been sitting here reading this thinking ?stupid people, why even try this?" And as I'm thinking it I subconsciously download and flashed the radio my self. Curiosity took over and just made me do it. No difference at all for me. Still 1 bar, still 750 mps speed test ( its only that high because I'm past peak hours) oh well
Sent from my Kindle Fire using Tapatalk
It is the "easy" way of doing things root in the Android world. Of course. easy doesn't equate to working...
Just flashed the radio update with no problems. Xionia Recovery FTW. I have decided to stick with xionia since IHO and BobZhome's recovery doesn't work with updating PRL from my experience. Seems to be the champ of them all IMO (don't hurt me)
Thanks a bunch LeslieAnn for giving me something to do on my Monday night after work.
AND OMG is it just me or did my phone become SHINIER right after I updated the radio..?
SHINY! :-!
I had a similar problem with my camera button today when my OV took a good fall. Noticed later when trying to reach recovery menu with hardware buttons that the camera button was stuck halfway down. I got curious and broke out my electronics tools a couple screws and some prying at the metal casting later, the button freed itself up. After putting the battery cover back on the button got stuck again. So, I broke out the dremel and shaved some of the plastic off. The button works fine again. Phone is not as shiny anymore though. As always this is an at your own risk procedure.
I just had an interesting little episode that I thought might be worth sharing. I decided to flash "Amphetamines" onto my phone. It flashed ok, but upon reboot into OS I had no signal whatsoever. The radio was completely unresponsive. Wouldn't even toggle into Airplane mode. Had to do a restore to get it working again. So, unless you like having to restore for no good reason, might wanna avoid Amphetamines after flashing the radio update.
Strange.
Could have been a fluke, hard to say.
I can't imagine that of the 100+ people who downloaded this, that you are the only one running that.
At least it's nothing permanent or difficult to fix.
I'm really new to the Optimus V tweaking, but I tried amphetamines--twice. Running bobzhome on my newer phone, I lost bluetooth connectivity after amph. Restored and all was good. Flashed amph again and BT seemed ok but lost phone connectivity (radio, I assume). Restored and all is good. I haven't attempted radio upgrade although with the CWM 4.xxx version I think it may work. Will wait for more reports.
Thanks to everyone, esp LeslieAnn for helping with the Optimus V.
Sent from my Terrific Toshiba Thrive with Tapatalk.
A good read
I'm not sure that my phone is entering emergency mode while trying that combination, all I get is the same LG logo that I have had since I bricked my phone. Also, where would I be able to find the zv8 firmware? Thanks for your help.
I flashed this yesterday and updated my PRL to the latest from Sprint. I do get better reception and service in my area, although it was not really lacking before. I live insanely close to the Sprint HQ.
I updated to 60685 PRL found here.
I followed this method to update my PRL.
To flash the PRL, I had to switch back to CWM Recovery from AOSP(Xionia will work as well). It is old but I have it on my sdcard from the last time I updated my PRL.
To install the radio, I simply flashed back to IHO Recovery which stays on my phone as normal. It took a whole 15 minutes to do this all with not a single hiccup.:cool:
Thanks to all the Devs making this happen. I am currently running latest Backside/V9 Radio/60685 PRL like a beast.
Go to this page for the guide
Go to this page for the zv8 or other stock cab files
One thing I forgot to mention is that you will sometimes have to go into recovery to erase data. To do so just power off. Then hold the home and volume down keys then press the power button you'll go into stock recovery. hit data factory reset.
Reactions: grnsnake
Status
Cs Kredivo
