Pdanet for tablet Bluetooth DUN Help!
skitzer9
110
13
I recently bought the Asus Transformers Pad TF300T (running ics 4.0.3) and started using Pdanet for tablets to tether my HTC evo 3D (running GB 2.3.4) with my tablet via Bluetooth DUN and the browser and some apps work, but theirs some other including the Play Store that don't. Also when I look at the notification area it shows the Bluetooth symbol and on the side it says "No Internet Connection", but I know that is not true. Does anybody know how to fix it so that the internet works with all apps? Any help would be appreciated. Sorry for my bad English, my main language is Spanish. Oh and btw the table is awesome!!!
Sent from my ASUS Transformer Pad TF300T using Android Central Forums
So I looked around and found this, haven't tried it so I don't know if it works
Sent from my PG86100 using Android Central Forums
Haven't had that issue pdanet on tablet foxfi on thunderbolt.
All seemed to work well between my tf300 and spectrum
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
I'm using FoxFi on my EVO 3D from Sprint to connect to my Transformer Pad 300 via Bluetooth, and I have found that sometimes I get a notification that I have no internet connection. What I have found is that If I turn off the wifi on the tablet and just try to connect using Bluetooth, I will often get this message. However, if I turn on wifi, even if I have no connection, I find that apps will work.
So maybe these apps just need the illusion that they are connected via wifi in order for them to work. It's worth trying, if you have not done so already. If so, well, I wish you the best.
Reactions: skitzer9
Thanks for the reply. I tried it but sadly with no results, there still some apps that don't have internet access when using Bluetooth DUN. Still thanks for the reply, its much appreciated.
I had the same issue it's not pdanet vpn blocking your connection it was ssl I had the rong date and time set so all ssl and https connectors where blocked because security keys where out of date
Samsung Note 4 Bluetooth and samsung tab4 smt530un android 5.0.2
Ps also fixed the problem with the pdanet USB connection between my note 4 and my laptop
fix was a monster USB cabe
Had tried factory and tough tested and Chinese specials
an it tech said I was dropping connection because of the phone was not getting enough current through the USB cable
DonJrPlayz1234
