Persistant LED (Won't Turn Off)
anon(3733516)
Active member
Nov 20, 2012
36
Hey all,
So I've noticed that whenever I turn my screen off, there is a red LED notification light that stays on. It goes away when I reboot, but shortly after I boot back up it'll just come back on.
I don't have any notifications or anything like that, which is the weird part. I do have Light Flow installed, but I did a thorough search through the settings and all that and it's not anything in there that's causing this.
Any ideas?
I had a similar problem when I installed liteflow except it was a blue led that kept on. I checked all the settings and everything seemed right and i uninstalled the app and it solved my problem. I can live without liteflow but I'm guessing the app is to blame.
I'll try deleting it....................
Yup, that did the trick. Shame, I just had Light Flow all set up! Ah well.
Thanks!
Lightflow is to blame. It's been well documented across the interwebs that Lightflow and the GS3 don't get along.
Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
If you still have Lightflow and you wanna use it try turning the device off then pulling the battery for about 30 seconds. That did fix it for a friend of mine. Let us know how it goes for you.
marik999
