Phone Acting Slow
im starting to doubt its credibility because it cant show me where my battery drain is coming from. garbage app if its not helpful
It never advertised it showed battery drain it shows how much battery you have left and what temp it is at, so what you said is a bit harsh dude. So how does it not having that affect it's credibility? Android has that built in, it's called the about phone/battery in settings.
System panel is primarily an app/task killer in the free version. In the paid version you get monitoring of the battery etc when you enable background monitoring service to record long-term resource usage by individual apps.
Free description:
SystemPanel Lite integrates a task manager, system monitor, and detailed device information.
No ads.
Full version ($2.99) adds app manager (installer/uninstaller with multi-version APK archival), and long-term application resource monitor to solve app-related battery life problems.
Paid description:
SystemPanel integrates a task manager, app manager (installer/uninstaller with multi-version APK archival), and system monitor.
Solve your battery life problem by enabling the background monitoring service to record long-term resource usage by individual apps.
So you may want to try the paid version if you don't have it, if you do have it I think the Dev of the app would appreciate your rather blunt review of their app more than me. I never mentioned anything about the battery aspect of it.....sheesh. (And in my opinion it is far from garbage especially with 810 reviews with a 4.80/5 review scale.)
kankuraon
