Kevin OQuinn
AC Team Emeritus
- May 17, 2010
- 9,267
- 496
- 0
what? sorry but that is irrelevant. Take a computer graphic card run it at 100fps or turn on vsync, doesn't mean anything, the graphic card is still working like it was, it is just that the frame rate is capped, it doesnt mean the gpu is working any less. it is more about how much the game stresses your card and how graphically demanding it is, whether you are seeing 60 frames or 100 is irrelevant it is still producing same amount of heat.
Think about it this way, if you got a pure graphically demanding game, and it can bearly push 30 frames, it means it is taxing your card pretty good, if you turn down the settings to increase the FPS, does the heat go up? no, you are actually giving your card more breathing room, so less fps doesn't mean less heat, it could mean your graphic card is pused to limit and cant handle the game and will produce most heat, so more fps could mean less heat in some instances because you are reducing the overhead and your grahic card has to process less data.
Well I don't want to veer off topic here. But running at higher FPS does cause more heat. That is completely incorrect if you think otherwise. I only know this by doing benchmarks, and doing testing in games. Ones like Crysis... Anytime the FPS goes up the temp goes with it, because the card is workng harder. This is why I turn on V-sync to cap off at 60fps and I don't have heat issues.
I'm not sure the computer reference works here at all. Correct me if I'm wrong, but games in Android don't have adjustable graphics levels. You just get what's built in. So to me that would mean that you are only limited by the GPU's ability to render. So in a case like Tegra 2 you could definitly generate more heat with more FPS if the game is demanding enough. This would be due to the lack of a cap on FPS. On phones with a FPS cap this wouldn't be an issue because most modern GPU's in phones can run all the games at 60FPS. Yes, I'm sure that any game will also have dips in the framerate in especially demanding areas of the game, but I'm sure you guys get what I'm saying.
