Phone Dropping Data Connection AT&T
Text messages don't use data so your data connection isn't the problem as far as texts go. What's your signal like when you are having issues with texts?
Like I said in a previous message, my cell signal is crap at my house. When it does show I have service, it's usually in the -113 ~ -107 range.
I would try the following:
APN: wap.cingular
Proxy: blank
Port: blank
Unsername: WAP@CINGULARGPRS.COM
Password: blank
Server: blank
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS Port: 80
MCC: 310
MNC: 410
Authentation Type: blank
APN Type: default,supl,mms
APN Protocol: IPv4
APN roaming protocol
APN enable/disable checked and grayed
out on my phone
Bearer: unspecified.
There a few other ones depending on your plan, but this seems to be the most common one.
If you could msg me?
I have an Android LTE plan for ATT.. My previous phone was a Galaxy S3 any help on the APN?
I am using the WAP APN from at&t after having this issue with the hspa APN floating around the forums. WAP still gives me 4 to 9 Mbps down and it never drops. I'm using a 4G data plan as well.
sevogas
