Phone only works without sd card after ics update
That's good to hear. But i wonder why one app would cause such an issue. We should make a list of all installed apps and compare to see if we all have apps in common.
What apps have you re-installed so far?
Ok, I have added almost all the apps back. Does anyone having the reboot problem have the Aldi's grocery store app installed? Everything started failing again after adding that one back
steelers1,
I too have this reset problem. I have over 250+ apps between internal and SD storage. Removing SD card solves problem.
I too have been moving some files at a time back to the android_secure directory but I am beginning to believe that we are running into a storage resource problem with the EVO 3D internal storage. I too thought I found a bad APP but when I moved the APP back off the SD and removed a few other APPs off the SD when I moved the questionable APP back to SD the APP worked fine.
I have contacted HTC level 3 support and am working with them on the problem. I am trying to find out if there is a limit to the number or total size of APPs we can install on our EVO 3D. I did find out from HTC that even though you move an APP to the SD card only the APPs data and user data gets moved to the SD. The APP itself still resides in the phones internal storage.
I hope we all find a solution to this problem.
Michael Carvalho
