Phone password wont work and lock!
Arull18
My phone Pin is on but when i lock the phone and switch it on back it says Swipe to unlock.
In setting says secured with pin
!?If i click on it and type my password it says wrong password!!! And try again!!please help... i am using GALAXY NOTE4
Hi
You can try entering recovery and doing a wipe of the Cache Partition, see if that might help.Do you have the S7; similar issue have been reported with that device, after the update to MM. If the cache wipe through recovery won't help, I would suggest the below link to assist you in changing your password. If that won't help, then I'm afraid a factory reset is in order.
http://forums.androidcentral.com/am...s/640158-guide-forgot-password-read-here.html
Hope this helps!
Chris
