Phone stuck on rethink possible.
pinupgirl73
Hello, My motorola atrix 2 is stuck on the rethink possible screen, will charge however can't even do a factory reset since the computer doesn't reconize device, since its frozen on that screen. any help would be great! thanks
Have you tried taking the battery out holding power button. Then reinstalling the battery and starting it normally
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
Hello, no I have not tried that I have held the power button and volume at the same time, and it brings up a screen that says battery is ok ect. Im getting so frustrated I will try that. Thanks
vickyy
