Phone will not turn on after a screen replacement.
  • Start date Start date
A
Android Central Question
Hi! I recently had to replace the screen to my Motorola Moto Z3 by hand at home. I've done this before as the screen was broken and replaced once before, and this is the second time. It worked even with the broken screen. I used Google Assistant if I needed to check the time and such. Then, I held down the power button to turn it off. After replacing the screen, now the phone will not turn on. It does feel warm when plugged in, however. Anybody know what could be the issue and provide some solutions?
Try unplugging the battery for a bit.
mnwstl
