S susuki12002 Well-known member Jun 30, 2010 47 1 0 Aug 1, 2011 #1 Cant seem to figure out how to disable the LOUD shutter sound?
C ccfixx Active member Apr 19, 2010 32 2 0 Aug 1, 2011 #2 I keep my phone on Silent and I don't have the shutter sound.
S susuki12002 Well-known member Jun 30, 2010 47 1 0 Aug 1, 2011 #3 I tried that, doesnt work at all. Plus, when starting the camera feature it sounds like an old buick trying to start ....
M3wThr33 Well-known member Jun 1, 2011 80 4 0 Aug 2, 2011 #4 The shutter sound can't be turned off. The best you can do is wait for a root to remove the sound effect file. Of note, I realized today that the front-camera doesn't make a sound when triggering it.
Cubfan Well-known member Jun 19, 2010 947 60 0 Aug 2, 2011 #5 You could use Vignette instead and turn off the sound. Sent from my MB855 using Tapatalk
S susuki12002 Well-known member Jun 30, 2010 47 1 0 Aug 2, 2011 #6 Cool, thanks alot for the input guys.
A Alex222 Member Jul 5, 2010 18 1 0 Aug 2, 2011 #7 Cubfan said: You could use Vignette instead and turn off the sound. Sent from my MB855 using Tapatalk Click to expand... I've tried it with Vingette, still makes the shutter sound.
