Pie control
I believe it is a downloaded app from the Play Store that had to be turned on on accessibilities. If you search the Play Store for Pie Control there are several apps.
Thanks, I have tried a few of them. I was pretty confident that there wasn't a built in feature.
This feature is beginning to look carrier specific.
I'm not taking about air command. It is much more full featured.
My question is does everybody with a Verizon Note 5 have Pie Control as the final listing under Accessibility. Let's start there.
No
I have the Note 5 on Verizon running the latest version of Marshmallow and this is a screen shot of the bottom of the accessibility settings. I even have developer mode on. Clearly not a Note 5 feature nor a Verizon feature.
There are apps that control other apps that you have to turn it on accessibilities. I've used Greenify and ShutApp and they both have to be turned on on accessibilities after downloaded.
The same with Nova Prime, you have to enable it in accessibilities to allow it to create widgets.
cpoole89
