Pixel 2 XL Rapid Charger
I mentioned this in another thread, but it seems appropriate to repost here: I purchased this Satechi multi-port wall charger from Amazon, which provides both a USB-C PD rapid charge port that works effectively for my Pixel 2 XL and a Qualcomm Quick Charge port that works fine for my wife's Moto X Pure Edition, as well as two standard USB-A ports for charging other devices.
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6226111
And here's a car charger I got from Amazon that also provides both modes of quick charging:
I've been using these for less than a month, but so far we're very satisfied with both products.
Link seems fine: "Olixar USB Charger Hub - 5 USB Ports - 50W - Super Fast Charging Mains Charger - USB C & Qualcomm Quick Charge Compatible"
Not sure why it doesn't open in my phone. But thanks for sharing the name of the device :)
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6226118
Awesome! Thanks so much for sharing!!!
So I wanted to share what I ended up buying.
Bought this Meagoes car charger that came with one USB-C to USB-C and one USB-A to USB-C cables
https://www.amazon.com/dp/B077JMRPM...ag=hawk-future-20&ascsubtag=UUacUvbUpU6239258
plus I bought this iClever wall charger adapter:
https://www.amazon.com/dp/B00QTE09S...ag=hawk-future-20&ascsubtag=UUacUvbUpU6239258
I use USB-C to USB-C cable with the Meagoes car charger and use USB-A to USB-C cable with the iClever wall charger. BOTH combinations give me Rapid charging just like the Google's OEM charger that came with my Pixel 2 XL. I am a happy man :)
NOTE: Earlier before starting this thread, I bought a different USB-A to USB-C cable, I tried that with the iClever wall charger and it charges slow, shows "Charging" only on lock screen, not "Charging Rapidly". But the Meagoes USB-A to USB-C cable does charge faster. Therefore, not just the charger adaper alone but the cable also matter to achieve rapid charging.
Thank you everyone for your help and providing your valuable inputs.
I don't believe this should give you "charging rapidly". I believe only a full USB-C chain can provide the charge rate needed for this indication. What you have is a cable that is not built correctly and "tricks" the device into trying to draw more current than the charger can provide (which is dangerous).
The 2.4A rating on the ports is for Qualcomm QC devices, which the Pixel 2 XL is not. Max output is then 2A I believe, which is below the "charging rapidly" point on USB-C.
Does your cable show up on this list? What does it say the results are? https://docs.google.com/spreadsheets/d/1wJwqv3rTNmORXz-XJsQaXK1dl8I91V4-eP_sfNVNzbA/edit#gid=0
maryhurst515
