- Oct 21, 2018
- 1
- 0
- 0
So I used the dongle that came with the Pixel 3 XL to use my 3.5mm head phones yesterday. worked perfectly.
Today, I wanted to try out the USB C pixel buds that came with the phone. Plugged them in, turned on my music and the music was blasting from the phone speaker. After unplugging and plugging the headphones back in 10+ times. Still wouldn't work.
Called Google and figured out a solution. Now they work great.
For anyone who may have had the same problem, heres the solution:
Not sure why the phone would not detect the headphones to set them up in normal mode... But if you have the same issue, hopefully this will work for you.
- Restart the phone to Safe Mode (Hold power button, Hold "Power Off", then press "OK" to reboot to Safe Mode)
- Once phone is in Safe Mode, plug Google USB C Pixel Buds in. The phone should detect them and you should be able to go through the setup process.
- Once you're done setting them up, restart the phone normally and you should be good to go!
