MrSlippery519
- Oct 11, 2011
- 394
- 6
- 0
I am happy with anything over 4 hours of SoT on a consistent basis, sounds like both phones should do this easily.
I was perusing the Android Central review and was really shocked to hear this!
I realize the XL has a larger screen and QHD but even then I was expecting the opposite or at worse for them to be equal due to the significant battery bump.
//uploads.tapatalk-cdn.com/20161018/df988957980edd4798bac8f8efe4ce1a.png
Not necessarily. It is totally possible that the battery increase isn't large enough to compensate for the increased energy requirement of running at twice the framerate.
But then this was said in the same review,
"Daniel Bader has been using the smaller Pixel for the past week, and has found its performance generally good, though more susceptible to battery drain from heavy usage."
"As long as you're willing to top up the phone once or twice a day, even for a few minutes, the smaller Pixel's battery life should be fine, but if you're a truly avid user — and who among us isn't? — then the Pixel XL, or a diminutive battery pack close at hand, is probably a better option."
I have a very hard time believing this. 1440p is not that much more intensive compared to 1080p in terms of CPU usage and battery drain. The massively bigger battery and identical hardware means they should, at the worst, be equal. But I would expect xl to live longer.
It's nearly double the pixels.
It has nothing to do with OLEDThat's true, but the way OLED works means it should be that much worse. Screen draw is a minor factor to system resources. It will cause more drain when gaming, but that's about it.
So I've had the smaller Pixel since the 5th, so longer than the review units BUT theirs run retail software and mine does not. Small Pixel gets battery life very near to the 6P, little bit better. My problem is not having an XL to compare it to.
Vs the 6p it handles poor cellular signal strength much better.
The battery size difference is substantial, but a 5" 1080p display is going to need a lot less power than a 5.5" QHD display. By heavier days I assume he means gaming and other graphic heavy apps, so for me it wouldn't make a difference because I really don't play games on my phone.
Day one SoT for the standard Pixel...https://www.reddit.com/r/GooglePixe..._one_with_the_pixel_over_5_hours_40_mins_sot/
If that remains consistent that is more than good enough for me.
In both cases you're likely to get a decent, full day of use out of the Pixel and Pixel XL, though the XL fares a little better on heavier days.
