Plantronics Voyager Edge got my S6
Kalvin Kerns
Trusted Member
Feb 14, 2014
1,586
Yesterday I picked up this great new companion to my S6. So far it's a gorgeous, high quality piece of kit that I highly recommend.
Great design with water and sweat residence. Battery lasts 6 hours plus another 10 from the charging case that comes with it. I think it looks and feels comfortable on as well. I didn't even need to try one of the extra ear pieces that came with it. Was prefect right out of the box. Expensive at $129 from Best Buy, but hopefully worth it. Check out it.
I've been using that BT for about 7 months now. It works and sounds great. I installed the companion app on my phone and PC to make the most of its features also.
The only downside is that the rubber earpieces wear really quick but you can get replacements at plantronics.c0m or on amazon.
Enjoy it as it's a great BT!
Actually I believe you turned me onto it lol.
Now I just need to update the firmware, hopefully tonight. I installed the Findmy headset app, it has good reviews.
