play store images and screenshots not loading
Re: play store ies and screenshots not loading
Hi,
I'm having the same problem with Play Store images and I wanted to try your suggestion, but the "save" button grays out after I change the IP to "Static". I've tried populating the password field first with the right password but nothing changes. I've also tried changing the dns settings in my router setup page, but the wifi settings in my phone show the same dns I had. Any ideas?
Thanks in advance.
Hey, If you have not yet solved this problem the process is same .
All the fields need to be filled in order to save . first see your ip address before changing (default) in the network you are currently connected.
oval_clarity
