Play store (no connection retry)
Amazing! I had noticed that my clock had changed, but thught nothing of it...worked a treat. Saved me hours...no pun intended.
My play store not working
There must be a dozen possible fixes in this thread. Have you read the thread, and tried any of them yet? Do that first, and if it still doesn't work let us know. But don't ask us to repeat what you can read just as easily as anyone else.
Maybe this might have been helpful if I could download ES File Explorer on the Play Store. Unfortunately, my Play Store is not working that's why I've come here. Thanks for the help anyway.
my play store has not been working for the last 36 hours and i have tried everything on this thread. My phone was rooted and i unrooted it rebooted, deleted freedom, tried the airplane mode, tried wifi and mobile data, tried ##72786# and got an error saying connection problem or invalid MMI code, i tried to create a new google account but everytime i get to the screen where i make a gmail email account it says the email is already taken which it is not bcuz i have tried hundreds of wild names, and lastly i have even factory reset and it still does not let me connect and i cant even sign in now bcuz it says there was a connection error while signing in. my phone is a LG Optimus Pro G e980
Finally found a way to fix the store for me.
**ROOT IS REQUIRED!**
Here is a short fix for the No Connection Error on play store. It may not work on all devices.
1. Download Total Commander from Play Store.
2. Install it in your Device.
3. Open Total Commander and goto Root of System. (/ )
4. Open the etc folder.
5. Find the file named "hosts", and hold it for 3 seconds. Choose edit file, and choose Total Commander Text Editor if prompted.
6. Add ---> " # " <--- before 2nd line like this " #74.125.93.113 android.clients.google.com "
7. Save the file.
8. Reboot your device
9. Add Google Account
10. Done!
I know it says download total commander from the app store but just go to this link since anyone here looking for a solution obviously can't access the play store.
Total Commander - Android
Once you download the apk move it to your phone via usb connection and then go to your phone and use any type of file manager app to access the apk and install it then follow the instructions listed above. This worked for me when everything else failed so i figured i would help anyone else in my situation.
Another thing you can try is: -
Open the phone dialler and type *#9900# to open SysDump then press the "...fast dormancy" button.
On my Samsung Galaxy Ace, this is the fifth option down.
(If it was on, the button will show "disable..." - If it was off, the button will show "enable...")
Maybe your mobile network (carrier) transfers data better with this off, or it's better switched on. Play Store can be very fussy about data connection quality, unlike a lot of other apps. Perhaps this is because it uses a constant stream of background data.
I have tried the "force stop, clear data, clear cache" but then again my play store still isn't working. What will I do? I wanna install tumblr so bad. Play store still says "retry" and "no connection" even though I'm connected to the internet. Please help me
BekaH
