Please help, Hafta unroot for replacement
turp415
59
8
so i took my phone to sprint because the phone quit reading the sd card, and then it wont regognize any hook up computer or charger. i dont know what to do. it will boot to fastboot mode and i can get into recovery, thats it, if it goes any further, it loops at the android screen.
. how can i fix this problem? really at a lose here. i have always found someone out therewho knows about this stuff. ANY sugestions will be appreciated. thanks for your time.
Will it read the sdcard or connect to computer while in recovery? If so, wipe all and reflash rom. If not, wipe data, cache, & dalvik cache and try booting up.
already did that and it still wont recognize it in recovery. sounds like sprint bricked my phone.
yeap tried it. ive tried about everything there is to try. researched it on all the forums. can't find a solution to this one.
If you take out the sd card and connect it to a computer using a card reader, do you have any files that have "qxdm" in the file name, on the root of the card? There is an SD Card fix for that, if it is in fact the case. The only solution I can think of is an RUU, but you'd need to be booted into stock recovery to apply it, which isn't possible to flash without a working sd card.
Are you sure the sd card won't mount in recovery?
it wont mount anytime. ive tried diffrent ones and tried to mount them while in recovery, but no good on any of them. it's just a weird problem i guess. ive never heard of it before
Yeah that's crazy. Sounds like you need a replacement.
Did you check the sd card for those files?
jochu
