Please Help!!!!!!!!!!! Having problems with phone
When your phone gets really hot (ex. when leaving screen on with long time-out while charging) the heat will cause the battery to expand (budge). Same thing happened to me with my HTC Droid Eris...it was literally smoking under my pillow when I woke up, and Verizon refused to repair it even though I had insurance so I came to Sprint. :)
Depending on the buldge it might not look different compared to a normal good battery. Calipers would be needed in some cases.
sent from my BAD A$$ Epic touch
It's definitely swelled up, i have the same problem. It's enough to where you can see the bulge through the back case but not enough to be THAT noticeable.
ok, so new here, i see how it spin it, but hhow does a "buldging"battery look??
This is what mine looks like. I'm trying to find a good supplier of an authentic samsung battery without the samsung price. Any suggestions?
Amazon has the Genuine Samsung OEM batteries for around $20 too. I replaced mine twice in the 13 months I've had the phone
Im having the same problem, Can anybody help my battery is draining very quickly also...I went to settings and battery and it says screen 86% but my screens brightness is down all the way...
Lisa... I strongly recommend you purchase a new/replacement battery for your phone. I also recommend that you only purchase the original Samsung OEM battery, not a third-party brand replacement. They can be found on Amazon for around $10... well worth the investment to keep your phone working well.
Amazon.com: D710 Samsung OEM Battery: Cell Phones & Accessories
sas9111
