please help, losing hope.
Could he flash a new recovery through flashboot and adb?
Sent from my A500 using Tapatalk HD
I know there's a way but I don't know the commands with adb. I actually have flashed a recovery from recovery via adb before but I just copied the lines from something I read.
If you can still access the recovery, you just need to flash the Cannibal Open Touch recovery.zip from the current recovery. Then go to the advanced section of current recovery.
Choose to reboot recovery, which will boot into the COT recovery.
Then find the "fix recovery loop" option.
That should fix you right up.
If that doesn't work then we'll try fastboot commands to "flash erase all", then push and flash new recovery.
Problem there is in the op he said he couldn't select anything.
Lol feels weird trying to fix the ops problem when it seems he's not around anymore... Oh well at least it'll probably help someone else thru Time
Duh! Brain ssllloooww.
Looks like it's adb and either shell or fastboot commands. Not a problem. Piece of cake.
Assuming the OP returns.
ilech
