PLEASE HELP! Phone not loading!
dmartin1972
63
I need help please! I have been using my fascinate fine all day. al of a sudden, i rebooted my phone and it will not work. When I reboot and unlock, i get this error:
The process android.process.acore has stopped unexpectedly. Please try again.
when i hot force close it continues to give me this message. over and over.
I have tried everything i can think of. battery pull, wipe data, even a restore. I am stumped.
My fascinate is rooted and has clockwork mod recovery.
PLEASE HELP!
Turn the phone off, and hold both volume buttons down when you power back on. This will take you into the stock recovery. Once there, use the volume buttons to scroll down to "update.zip" and select with the home button, which will take you into cwm recovery. From there you can go down to backup and restore, but use the power button to select. Reload one of your backups and this should get you working again
I have tried that as well. Had 2 backups there. tried both of them and still getting it when it reboots.
THAT DID IT!! Thank you so much for your help! Now I am having another issue, i went back into the market to start downloading my old apps and i am getting an error that says not enough room to install???
Also, everytime I reboot the phone, it goes trough the setup wizard and I have to set everything up all over???
I just looked under available phone storage and it says 0.00!! What happened? I am really confused now.
Sounds like voodoo strikes again. Now you need to completely remove voodoo, search for the thread over at xda
WOW! What a night. Well, tank you to all who have shown me where to go to work on these issues. As of right now, I am all up and running. I did have to remove vodoo and got my storage back. I think I am gonna steer clear of Vodoo.
Just curious if any of you know why that happened to me all of a sudden? It was fine all day and then BOOM! Thanks again to you all for your help!!!
motoJunkie1
