Please Help: Phone will not charge!
ccannon917
18
Hi guys! I'll start by saying this is all very new to me. I'm a complete NOOB, but I am very good at following instructions. Just last weekend I decided to go to Froyo from Eclair. I flashed (Odin method) the Superclean 2.6 EB01/EB16 Froyo rom (if I even said that right) properly. My phone worked perfectly, and I didn't see any problems. Until today, that is. I just noticed my phone is not charging. I have the same OE battery that came with it. I wanted to go back to stock thinking that might fix it, but it seems as though the phone doesn't recognize anything via the USB port. What may be the problem, and how do I fix it? Any help is greatly appreciated!!
did you try checking off USB debugging mode?
IDK if that'll fix it but it's worth a try
it's under settings>applications>development
see that it's checked off, back out then plug it in and see if it'll recognize anything
Reactions: ccannon917
Thanks, but I just checked and it is off. I'm now at 57% battery life and can't figure anything else to do.
I feel like a loser!! Sorry to waste your time. I told you guys I'm a complete NOOB! I tried my brothers cable/wall charger and it works fine. My only problem is a bad USB cable. I really do appreciate your trying to help me.
sorry... i meant check it off as in the box should have a check.
and i think Braydon meant "turn it on" as in debugging mode is on and see if your computer recognizes the phone.
Gotta love word play ;)
Glad its not the USB port on the phone!
dbs2
