Poco m3 pro 5g keeps rebooting and going to recovery mode ?
toke nip
5
hi
i was using my phone and it start to rebooting and go to recovery mode
even on SAFE MODE rebooting and go to recovery menu
what do i do ?
I made you the owner of the original guest post to make it easier for you to find.
There's no way to backup data if you can't boot normally. That's why it's always important to keep your data backed up or synced on a regular basis, in case of an issue like this.
Is there an option to wipe the cache partition in your Recovery Menu?
there is no wipe cache option
there is an option that is connect to mi assistant but i cant find the worked version on pc
i have my poco account
my laptop recognized my device in recovery mode and i unlocked the OEM but their software old and wont detect my device
is there any chance if i disallow a permission on system setting this happens if yes i have to re allow which permission ?
Thanks
A PC will usually recognize a USB device when connected, even if that device isn't booting properly -- it doesn't mean the PC can communicate properly with it to access the data. The connected device has to be operating normally.
Let's see if a couple of our members @dangerousfen and @Madd62 (who are much more familiar with Xiaomi phones than I am) have any ideas. It's also worth posting your question in the forums at XDA-Developers.com, where people may be more familiar with this kind of thing.
yeah but ADB is connected if can recognize my device then just have to operate the script with unlock OEM i think !? maybe not
appreciate your help
Not sure, sorry. The problem is that even if you could send ADB commands, I doubt any of those commands would allow you to boot the phone properly, if the firmware is corrupt. And I'm not aware of any way to access the data on the phone using ADB.
BOb_marley
