I Ichi_Bear Well-known member Nov 4, 2011 168 0 0 Dec 28, 2013 #1 Can anyone suggest a decent USB portable hard drive and cable for my new Nexus 7? I'm looking for a 500 GB capacity. It won't be exclusively used for the Nexus. Thanks in advance. Sent from my GT-I9300 using Tapatalk
S sparksd Well-known member Aug 20, 2010 1,098 9 38 Dec 29, 2013 #2 You may want to check this thread out over at xdadevelopers - some info in what you will run into when trying to use a hard drive with the Nexus 7: Access your WD 2tb Passport HD with OTG and Power bank - xda-developers
I Ichi_Bear Well-known member Nov 4, 2011 168 0 0 Dec 30, 2013 #3 sparksd said: You may want to check this thread out over at xdadevelopers - some info in what you will run into when trying to use a hard drive with the Nexus 7: Access your WD 2tb Passport HD with OTG and Power bank - xda-developers Click to expand... Thanks Sent from my GT-I9300 using Tapatalk
