Porting help.
To do :
•Use that RE that's on there and delete all the untranslated apps. Reboot. That'll fix the txt. MMS worked for me :/. Ill look into it.
Also: VM turned my phone off for some reason. I sent back the replacement but they didn't believe me. So I can't test MMS and 3G. :(
Has so much bloatware and apps i cant uninstall and randon net monitor.. Locksceen isnt even that good. And on top of that the status bar isnt even iphone ish :O Video was a lie..
I still appreciate the work :D The triangle at the top right is annoying me D: i wish the orignal one had the ios status bar and fully working 3g
I believe he downloaded another one, I got one totally different but with iphone's statusbar.
The O.P should Have Lurkin, original and BackHandLegends Zips
So you have a option of 3 :-$
same here! lurking rom is really cool i did some changes on the settings and i got.it looking cool but i notice that i cant use google play?
oval_clarity
