Possible battery issue?
terrrrrible
97
3
Was playing around a bit with my phone today and started thinking I was having battery drain a bit quicker than usual. Was looking through the battery settings and noticed under the chart that the bar for WiFi is solid green all the way across up to the current time. I've had my wifi off all day, is it still supposed to be like this? Or is it possible another service on the phone is using it?
Here are some usage screen shots:
Imgur: The most awesome images on the Internet
Not sure if something is up or I'm just thinking I should have better battery life than what I'm getting.
Thanks
That first screenshot is telling me that your Wi-Fi was on the whole time.
But as the previous poster noted, you had lousy cellular coverage most of the time, and that'll contribute to poor battery life like nothing else.
Also worth noting in the first screenshot is that the phone was awake quite a bit more than is accounted for by your screen on time - there may have been an app preventing the device from going to sleep. If that particular behavior continues you may want to do some further digging into what's keeping the phone awake.
Do you have scan for wifi always in your location settings? That would make your wifi line show solid all the time.
dandecrypted
