Possible bricked Evo. Help please.
Larson730
So I was running a basic rom on my evo and decided to flash another. Did all the necessary steps and when I rebooted, i get nothing. I see the boot animation then black. I've tried several Roms and am not sure where to go now. I've tried to use RUU to unroot it but can't seem to get the program to work. When I reboot to the bootloader I get an error saying no image found. I think that my sd cared may be messed up. I'm new to this and hope I didn't screw anything up. Help is very appreciated!
Flash the boot.img from the Rom your using with fasboot. See if that works. There is a thread around here somewhere on it.
Sent from my EVO using Android Central Forums
Did you backup your phone before you flashed the ROM? If you can get back into the Recovery, try to load your backup. Good luck.
My phone:
Evo 4G LTE
LazyPanda
JEWEL PUT SHIP S-OFF RL
HBOOT – 1.12.1111
Radio – 1.02.12.0427
Recovery – TWRP 2.2.2
ROM – CyanogenMod 10
I tried to upgrade to TWRP 2.3.1:
Download - Bootloader Method:
Download Page Bottom | Techerrata
Download the file above and rename to PJ75IMG.zip and place it on the root of the sdcard. Boot into bootloader and accept the update. Boot back to the ROM and rename/remove the file
Everything went well and the update was successful. However, my phone is stuck in a boot loop – clocking on the Cyanogen boot animation (the word “CyanogenMod” in the middle of a circle going clockwise on the outside and counter-clockwise on the inside). I let it run as long as 30 minutes - - no luck.
I am able to long-hold the power button to bring me back to the Upgrade screen. If I hit yes <VOL UP>, it updates successfully and asks to hit power to re-boot. If I hit no <VOL DOWN>, the upgrade is aborted and I am asked to hit power to re-boot.
I‘m thinking my options are:
1. Try the “RegawMOD EVO 4G LTE Rooter” to get back to where I was
2. Try the 1.13.165.1 RUU to get back to factory and then re-root.
3. ???
Any thoughts or suggestions?
Thanks,
Gary
My phone:
Evo 4G LTE
LazyPanda
HBOOT ? 1.12.1111
Radio ? 1.02.12.0427
Recovery ? TWRP 2.2.2
ROM ? CyanogenMod 10
Everything went well and the update was successful. However, my phone is stuck in a boot loop ? clocking on the Cyanogen boot animation (the word ?CyanogenMod? in the middle of a circle going clockwise on the outside and counter-clockwise on the inside). I let it run as long as 30 minutes - - no luck.
I?m thinking my options are:
1. Try the ?RegawMOD EVO 4G LTE Rooter? to get back to where I was
3. ???
Thanks,
Gary
I FIXED IT. Someone said that as long as the new "PJ75IMG.zip" was on the card, it would loop. I figured I would remove the sdcard. I knew there was a chance of corruption, but I removed it and got into TWRP. It was 2.3.1, but I reloaded 2.2.2., updated it clean full wipe, NAND restore and back in business.
This was the most scared I've been since I started rooting (my Hero, my OG Evo and my Evo 4G LTE).
WHEW!!!
harristn
